Dave_Wu_20200's avatar
Dave_Wu_20200
Dec 09, 2011
Rate Shaping using url and ip address
Hi Guys,
I am attempting to write a irule to shape bandwidth by using source ip address xxx.xxx.xxx.xxx and host of xyz.com.
Could I use something like that
if { [HTTP::host] equals "XYZ.com" && [IP::client_addr] == xxx.xxx.xxx.xxx }
rateclass rateshape1
Is my code correct?
Thanks in advance
  • hoolio's avatar
    hoolio
    Hi Dave,
    Just a couple of small suggestions. Set the host to lower case as it should be matched case insensitively. Also, using an equals operator like == or eq would (eventually) do a string comparison. A bitwise comparison with IP::addr will be more efficient and support CIDR.
    http://devcentral.f5.com/wiki/iRules.ip__addr.ashx
       if { [string tolower [HTTP::host]] equals "xyz.com" && [IP::addr [IP::client_addr] equals xxx.xxx.xxx.xxx] }
    Aaron
