cawong23_136311's avatar
cawong23_136311
Oct 10, 2014
Rate limit per ip and url
Hi dudes,
Recently I wrote a irule to rate limit a specify ip to visit specify url. However I found it doesn't work and no log can be shown. Is that anything that I can fine tune?
    when RULE_INIT {
set static::maxRate 3
set static::windowSecs 1
if { ([HTTP::method] eq "GET") and ([[string tolower [HTTP::uri]] contains "leisurelink" ] ) } {
     blacklist
    if { [ [IP::client_addr] equals 10.0.0.0/255.0.0.0] }{
     set variables
    set limiter [string tolower [HTTP::uri]]
    set clientip_limitervar [IP::client_addr]:$limiter
    set get_count [table key -count -subtable $clientip_limitervar]
     main condition
    if { $get_count < $static::maxRate } {
        incr get_count 1
         table set -subtable $clientip_limitervar $get_count $clientip_limitervar indefinite $static::windowSecs
        log local0. "$clientip_limitervar has exceeded the number of requests allowed."
        drop
        return
    when RULE_INIT {
      if { ([HTTP::method] eq "GET") and \
         blacklist
           set variables
           main condition
            incr get_count 1
            drop
            return
    The statement [[string tolower [HTTP::uri]] contains "leisurelink" ] does not require the outer set of [ ].
    The command [ [IP::client_addr] equals 10.0.0.0/255.0.0.0] is not valid. You appear to be missing the IP::addr command to make this work. [IP::addr [IP::client_addr] equals 10.0.0.0/255.0.0.0]
    See how you go with that.
