random redirect loop with F5 in place
So I have a Virtual F5 Big IP environment, version 11.5. setup to load balance between a few servers. I have two pools and four VIPs for HTTP and HTTPS per pool. I am really new to F5 and have run into an issue where random links throw the user into a redirect loop. This only happens with the F5 in place. Everything is in a virtual environment, except for the client machines accessing the web servers. The web servers have two NICs. One that connects to the F5 and one that connects to a management network. The gateway is set to the F5 on both NICs. I realize this wont be all of the information needed to solve this problem so please feel free to requests specific information and I will provide as much as possible.
Thanks!
- Kevin_Stewart
Employee
Are there any iRules applied to these VIPs?
- technoe_159637
Just one. A custom rule written to avoid one of the redirects.
when HTTP_REQUEST { if { ([string tolower [HTTP::uri]] starts_with "/dir/dir/file.aspx") and ([string tolower [HTTP::header "Referer"]] contains "login-blah.team") } { HTTP::redirect https://www-env.team.blah.com } } when HTTP_RESPONSE {HTTP::header insert X-UA-Compatible "IE=EmulateIE9,RequiresActiveX=true"}This works for a very specific redirect.
- Kevin_Stewart
Employee
I guess the next question would be, what type of redirect loop? HTTP-to-HTTPS-to-HTTP? Redirecting from what to what? What is the relationship of the HTTP and HTTPS VIPs?
- technoe_159637
Great question. Here's what I understand. Some of the pages are secured, most are not. The initial request comes into the app server, which then redirects unauthenticated sessions to the single-sign on server. Once authenticated, the sessions is directed back at the app server. The current iRule prevents a loop here. However, the second loop is pure http and subsequent loops are inconsistent with the above (first) loop. When back at the app server the client can click a link the moves them to a page in a parallel folder on the app server. For about a dozen links, this throws the client into a loop. Clear as mud?
- Kevin_Stewart
Employee
Can we establish what the redirects actually look like, as in what the redirect is from and to where it is pointing? The easiest way to do that is probably a client side capture tool like Fiddler. And a few additional questions:
Are the redirects from HTTP to HTTPS, or the reverse? Or across different hostnames? Is it redirecting back and forth between two URLs?
Do you have the redirect rewrite option enabled in the HTTP profile?
Do you have any HTTP class or rewrite profiles applied to the VIPs?
Can you elaborate on what happens if you remove the above iRule?
- technoe_159637
The first redirect is from HTTP (hostname1) to HTTPS (hostname2) to HTTPS (hostname1). Redirect Rewrite option has been turned on and off in the name of testing. Neither option seems to matter.
The only profile applied is the default HTTP profile. It is applied to ALL VIPs.
Here's the entire process without the iRule: Enter URL for app server App server looks for an authenticated session. If not authenticated, app server redirects to single-sign on server. Single-sign on server authenticates and redirects back to app server. (Loop begins) App server immediately redirects session back to SSO server, but since session is authenticated on SSO, SSO redirects back to app server. It remains this way until you refresh the page, then magically, the app server loads a page for the authenticated session.
Thanks for all of your help.
- Kevin_Stewart
Employee
What is in the request to the app server that indicates the user is authenticated? Is it supposed to be a cookie? Query string? Form POST? Can you determine, from a client side (Fiddler) capture, if that value is getting transmitted correctly to the app server after authentication? What is different in the request to the app server before and after refreshing the page? A new cookie perhaps?
- Baron_of_StrathHistoric F5 Account
Is the single sign on being handled by the F5? Is the cookie domain set sufficient to cover all links?
- technoe_159637
The single-sign on is being handled by the second server (hostname2). I'm not sure about the cookie domain. I'll have to involve one of the developers.
