Chris_199321's avatar
Chris_199321
Oct 12, 2016
Question for APM Edge client Always-Connect
Some questions for Always Connected feature in 12.1 1. Can I check the location DNS Name with IP and DNS-Suffix or DNS ip address only?
My configuration: Location DNS Name: 10.10.10.10, domain.com
Result: If i put domain.com and DNS server 8.8.8.8 on endpoint device, edge identify the network as non-Enterprise network and connect sslvpn.
  1. If i kill the edge client in process, is there any log in windows/edge client?
  2. I connect to non-enterprise network and does not go through the complete login process. My network connectivity is restricted by edge client. I found that i am still under restriction even if I kill the process and stop the services. What is the mechanism behind this? I am able to release the restriction if i change the ip.
Thanks!!
  • Fail to correct the format as it is identified as spam message..
    1. Can I check the location DNS Name with IP and DNS-Suffix or DNS ip address only? My configuration: Location DNS Name: 10.10.10.10, domain.com Result: If i put domain.com and DNS server 8.8.8.8 on endpoint device, edge identify the network as non-Enterprise network and connect sslvpn.
    2. If i kill the edge client in process, is there any log in windows/edge client?
    3. I connect to non-enterprise network and does not go through the complete login process. My network connectivity is restricted by edge client. I found that i am still under restriction even if I kill the process and stop the services. What is the mechanism behind this? I am able to release the restriction if i change the ip.
    Thanks!!
