farache_28983's avatar
farache_28983
Jul 17, 2013
Question and assistance with monitor
Hi Guys,
I am ttrying to configure a monitor for a few webservers that will do the following:
1. Use the below URL for health check
=1 \r\nHost: \r\nConnection: Close\r\n
Receive String is:
HTTP/1\.(0|1) (2|3)
Receive Disable String is
HTTP/1.\(0|1) (4|5)
This does not work. So the question is , does the port number has to do anything with it? can I use the URI or should i use the full URL? this URL is in each server, So i technically just need to change the host portion.
--->For (2) and (3), I've created an Irule for checking the response for each request as follows
when HTTP_RESPONSE {
if { ([HTTP::status] == 500 ) and ([active_members [LB::server pool]] >= 5 )} {
LB::down
Question with this type of passive monitoring is, when the pool member is marked down when an 500 error shows, what happens with it when the error goes away and the server is healthy? How can it be enable again? I think that i can obtain the same monitoring with only this passive monitoring, but not sure how to mark the pool member as up when healthy.
hope tihs makes sense
  • For (1) , I've created a monitor that will do a GET to the uri like this
    GET /hotelrates/getSampleExpressDeals.do?noOfDeals=1 \r\nHost: \r\nConnection: Close\r\n
    Receive String is:
    HTTP/1\.(0|1) (2|3)
    HTTP/1.\(0|1) (4|5)
    This does not work. So the question is , does the port number has to do anything with it? can I use the URI or should i use the full URL? this URL is in each server, So i technically just need to change the host portion.have you run tcpdump on bigip to see what is going on? Aaron has written excellent monitor troubleshooting article as below.
    Troubleshooting Ltm Monitors by Aaron
    https://devcentral.f5.com/wiki/advdesignconfig.TroubleshootingLtmMonitors.ashx
    to change host name for each server in pool, i understand you have to use external monitor.
    HTTP Monitor cURL GET With Host Specific Headers
    https://devcentral.f5.com/wiki/advdesignconfig.httpmonitor_curl_getwithhostspecificheaders.ashx
    when the pool member is marked down when an 500 error shows, what happens with it when the error goes away and the server is healthy? How can it be enable again?Note: Calling LB::down in an iRule triggers an immediate monitor probe regardless of the monitor interval settings.
    LB::down
    https://devcentral.f5.com/wiki/iRules.lb__down.ashx
    hope this helps.
