Chakravarti's avatar
Chakravarti
May 27, 2020
Python-F5-SDK-GTM
Trying to use F5 Python SDK for GTM Automation task, but some how initial authentication not working.
Below Error i get.
icontrol.exceptions.iControlUnexpectedHTTPError: 404 Unexpected Error: Not Found for uri
i am able to connect LTM using this
my GTM ver is BIG-IP 11.5.3 Build 2.0.196 Hotfix HF2
Can some help on this .. Thank you ..
  • i'm not sure GTM was supported on iControl REST in v11.5.3. You should test with Postman or similar to check that it actually works.
