Python code using Parallel-SSH library to connect to F5 BigIP
I'm trying to use Parallel-SSH (Python library) to connect to F5 BigIP.
This simple code works perfectly toward a Red Hat server, but it fails toward F5 BigIP:
Here is the error message:
pssh.exceptions.AuthenticationError: ('Authentication error while connecting to %s:%s - %s - retries %s/%s', '<IP address>, 22, AuthenticationError(), 1, 1)
Has anyone gotten this to work with the Parallel-SSH library?
I have already tested Paramiko and that works, but I want to use Parallel-SSH.
- MIS
Hello,
I've tried mimicking the code shared here, but it returns a similar error
pssh.exceptions.AuthenticationError: ('Authentication error while connecting to %s:%s - %s - retries %s/%s', '<IP_address>', 22, AuthenticationError(), 3, 3
A difference I noticed is that my user, when connected through SSH, gets placed in TMSH instead of BASH.
I've tried
from pssh.clients import ParallelSSHClient hosts = ['<IP_address1>', '<IP_address2>'] client = ParallelSSHClient(hosts, user='<MyUser>',password='<MyPassword>') cmd = 'show sys clock' output = client.run_command(cmd) for host_out in output: for line in host_out.stdout: print(line)and
from pssh.clients import SSHClient host = '<IP_address>' s = SSHClient(host, user='<MyUser>', password='<MyPassword>') cmd='show system clock' res = s.run_command(cmd) print(res) for line in res.stdout: print(line)Thanks in advance. All help will be appreciated.
My versions
- WSL, Ubuntu 22.04.4 LTS
- Python 3.10.12
- parallel-ssh 2.12.0
- ssh-python 1.0.0
- ssh2-python 1.0.0
- BIG-IP 15.1.10.3
- JRahm
Admin
I'm not able to get ssh2-python installed on either my intel or apple silicon mac currently, erroring out. Might be a little while before I can troubleshoot. I'm guessing since you're in the tmsh shell that this won't work as advertised.
- MIS
JRahm,
Thanks for your prompt response.
In my uneducated and unexperienced state, I was hoping it would work. In the end, it's just a command in the terminal, I thought.
If it's within my capabilities, I'll be glad to try anything you can suggest.
I'll see if I can make my user fall into BASH instead of TMSH when SSHing to the F5s.
Regards,
- JRahm
Admin
For anyone else trying to get this to work on Mac...first:
- brew install cmake
- (In a venv) pip install ssh2-python
- (In a venv) pip install parallel-ssh
Will post back on details if I can get it talking to BIG-IP. Just took a minute to get through the pip errors for this module.
UPDATE: Got it working. Works with password or key file if you copied your ssh keys to BIG-IP.
from pssh.clients import ParallelSSHClient hosts = ['ltm1.test.local', 'ltm2.test.local'] #client = ParallelSSHClient(hosts, user='root', password='default') client = ParallelSSHClient(hosts, user='root', pkey='/Users/justme/.ssh/id_rsa') cmd = 'tmsh list ltm pool' output = client.run_command(cmd) for host_out in output: for line in host_out.stdout: print(line) ### One output for brevity ### /Users/justme/PycharmProjects/playground/venv/bin/python /Users/justme/PycharmProjects/playground/sshtest.py ltm pool nginx-pool { members { 172.16.102.5:http { address 172.16.102.5 session monitor-enabled state up } } monitor http } Process finished with exit code 0- Eljay
Cirrus
Thanks, JRahm. Now I see that I wasn't crystal clear, I was using the single host client in Parallel-SSH. See examples for both single and multi host here: https://pypi.org/project/parallel-ssh/
I can adapt my code to this solution as well. But I still wonder if it's a problem with the single host client in the Parallel-SSH library.Here's an example that works in Paramiko:
from paramiko.client import SSHClient p = SSHClient() p.load_system_host_keys() p.connect('<IP>', username=<username>, password=<password>) stdin, stdout, stderr = p.exec_command('uname') print(stdout.read().decode())And here's the code using single host client in Parallel-SSH that fails:
import pssh.exceptions from pssh.clients import SSHClient s = SSHClient('<IP>',user=<username>, password=<password>, timeout=5, num_retries=1) res = s.run_command("uname") print(res) for line in res.stdout: print(line)- JRahm
Admin
Hi Eljay ... This also works just fine for me (both with key or password):
from pssh.clients import SSHClient host = 'ltm15.test.local' s = SSHClient(host, user='root', password='default') # s = SSHClient(host, user='root', pkey='/Users/justme/.ssh/id_rsa') cmd = 'tmsh list ltm pool' res = s.run_command(cmd) print(res) for line in res.stdout: print(line)Output:
/Users/justme/PycharmProjects/playground/venv/bin/python /Users/justme/PycharmProjects/playground/sshtest.py host=ltm15.test.local alias=None exit_code=None channel=<ssh2.channel.Channel object at 0x107c46ef0> exception=None encoding=utf-8 read_timeout=None ltm pool nginx-pool { members { 172.16.102.5:http { address 172.16.102.5 session monitor-enabled state up } } monitor http } Process finished with exit code 0My versions:
- python: 3.11.2
- ssh-python: 1.0.0
- ssh2-python: 1.0.0
- parallel-ssh: 2.12.0
- BIG-IP: 15.1.8.1
- Leslie_HubertusRet. Employee
This seems like a question JRahm may be able to answer!
