pycontrol, remove_wideip_pool() problem
Hello,
I'm using pycontrol v2 to control GTM WideIP. I'm trying to remove WIDEIP POOL with remove_wideip_pool()
When I run the python script, below error has been occured.
[merlinet@as-jw gslb]$ ./rmwp.py
No handlers could be found for logger "suds.client"
Server raised fault: 'Could not find element by name: pool_name'
here are part of the script:
new_set = glb.wip_obj.typefactory.create('GlobalLB.WideIP.WideIPPool')
new_set.pool_name = "real_www.domain.com"
new_set.order = 1
new_set.ratio = 0
try:
glb.wip_obj.remove_wideip_pool(wide_ips = [wideip], wideip_pools = [[new_set]])
except Exception, e:
print e
- JRahm
Admin
Remove the double brackets surrounding the new_set object and you should be good to go.>>> wip = b.GlobalLB.WideIP >>> pl = b.GlobalLB.Pool >>> wip.get_list() [/Common/test.wip.com] >>> wip.get_wideip_pool(wide_ips = ['/Common/test.wip.com']) [[(GlobalLB.WideIP.WideIPPool){ pool_name = "/Common/gpool1" order = 0 ratio = 1 }, (GlobalLB.WideIP.WideIPPool){ pool_name = "/Common/gpool2" order = 1 ratio = 2 }]] >>> pooldef = wip.typefactory.create('GlobalLB.WideIP.WideIPPool') >>> pooldef.pool_name = '/Common/gpool2' >>> pooldef.order = 1 >>> pooldef.ratio = 2 >>> wip.remove_wideip_pool(wide_ips = ['/Common/test.wip.com'], wideip_pools = pooldef) >>> wip.get_wideip_pool(wide_ips = ['/Common/test.wip.com']) [[(GlobalLB.WideIP.WideIPPool){ pool_name = "/Common/gpool1" order = 0 ratio = 1 }, (GlobalLB.WideIP.WideIPPool){ pool_name = "/Common/gpool2" order = 1 ratio = 2 }]] >>> - JRahm
Admin
huh, doesn't appear after second glance that my pool was removed. Odd. Let me pick at it a little longer - JRahm
Admin
Can you test on your version to see if this works. Even if I use the object as is returned from get_wideip_pool in the remove, it still isn't working on my v11 beta image:>>> a = wip.get_wideip_pool(wide_ips = ['/Common/test.wip.com']) >>> a[0][0] (GlobalLB.WideIP.WideIPPool){ pool_name = "/Common/gpool1" order = 0 ratio = 1 } >>> wip.remove_wideip_pool(wide_ips = ['/Common/test.wip.com'], wideip_pools = a[0][0]) >>> wip.get_wideip_pool(wide_ips = ['/Common/test.wip.com']) [[(GlobalLB.WideIP.WideIPPool){ pool_name = "/Common/gpool1" order = 0 ratio = 1 }, (GlobalLB.WideIP.WideIPPool){ pool_name = "/Common/gpool2" order = 1 ratio = 2 }]] >>> - JRahm
Admin
backed off to 10.2.2 and still see the same behavior. Probably user error on my part. I'm going to test the method from another language and see if it's a pycontrol issue or a method issue. - JRahm
Admin
so i have confirmed that the method works with a little ruby help from George. Now I have to figure out my pycontrol errors. - JRahm
Admin
OK, idiot me...figured this out. Requires two creates, one to create the pool definition, then one to create the sequence. Gets me every time!>>> pooldef = wip.typefactory.create('GlobalLB.WideIP.WideIPPool') >>> pooldef.pool_name = 'gpool1' >>> pooldef.order = 0 >>> pooldef.ratio = 1 >>> pooldef_seq = wip.typefactory.create('GlobalLB.WideIP.WideIPPoolSequence') >>> pooldef_seq.item = [pooldef] >>> wip.add_wideip_pool(wide_ips = ['test.wip.com'], wideip_pools = [pooldef_seq]) >>> wip.get_wideip_pool(wide_ips = ['test.wip.com']) [[(GlobalLB.WideIP.WideIPPool){ pool_name = "gpool1" order = 0 ratio = 1 }, (GlobalLB.WideIP.WideIPPool){ pool_name = "gpool2" order = 1 ratio = 2 }]] >>> wip.remove_wideip_pool(wide_ips = ['test.wip.com'], wideip_pools = [pooldef_seq]) >>> wip.get_wideip_pool(wide_ips = ['test.wip.com']) [[(GlobalLB.WideIP.WideIPPool){ pool_name = "gpool2" order = 1 ratio = 2 }]] - merlinet_60432
Point of the problem is how to assign GlobalLB.WideIP.WideIPPool to GlobalLB.WideIP.WideIPPoolSequence. right?
I correct my script as your suggestion. like
new_seq = glb.wip_obj.typefactory.create('GlobalLB.WideIP.WideIPPoolSequence')
new_set.order = long(0)
new_set.ratio = long(1)
new_seq.item = [new_set]
try:
glb.wip_obj.remove_wideip_pool(wide_ips = [wideip], wideip_pools = [new_seq])
print e
great! it works for me.
Very thanks
