Publish a web site that is already ssl
Hi! i have a p2p connection to a company. this company hosting an ssl web site for our workers. our workers connect to this ssl web site from our internal network by an f5 Virtual server i have created for this . now i want to publish the web site by portal Access Via (APM ) for workers at home. i tried to create a new portal resource and put a URI,Proxy Host,Proxy Port 443 and it is not working i think because of the site is SSL site. could you help me please how to configure it ?
Thanks,
Aviv Hassidim
- Brad_Parker_139
Nacreous
Sounds like you my need to enable SNAT to make sure the traffic isn't asynchronously routing.
- Brad_Parker_139
Nacreous
If its not a SNAT issue, have you verified that you have a server ssl profile attached to your virtual server?
- Brad_Parker
Cirrus
- Brad_Parker
Cirrus
- Aviv
Cirrus
Hi Brad ! if i publish an http site instead it works, so i dont think it's an issue of SNAT.
Does someone has other idea?
Thanks, Aviv Hassidim
- Aviv
Cirrus
Hi Brad!
i dont have a server ssl profile attached to the virtual server. i want to attach an ssl server profile , but i dont have the certificate key , do i need it?
Aviv
- Brad_Parker
Cirrus
no, you can just use the default serverssl profile, no need for a certificate or key here. - Aviv
Cirrus
when i attach the default serverssl profile the web site is not accessible even directly to the virtual server ,without apm. - Brad_Parker
Cirrus
did you attached the serverssl profile to your APM virtual server?
- Aviv
Cirrus
Hi brad!
can you help please?
- Aviv
Cirrus
Hi!
i will ask again just to be clear because i'm sure many of you folks already did that:
i have a website that i do not need to do ssl offloading at the bigip because the site is alredy ssl enabled at the source. i have create a standard VS with pool that contains the ip address of the website as node and port 443. when i insert into my dns the name of the web site plus the ip and try to surf to the site ,the site is up and running. i have an apm portal access that has some http applications uri Resources and i can start them throw apm portal access. after i set https application uri Resource i try to run the application from apm and i get this error : "DNS lookup error. The requested server does not exist" i have checked dns by dig commnad and i have resolving of the Resource and also curl and i get the page so dns is not the issue (i think). Brad suggest to set default serverssl profile on the apm virtual server and i did that but i get the same error.:You do not have permission to access this page. DNS lookup error. The requested server does not exist.
So how can i debug this?Thanks,
Aviv Hassidim
