Andrew_G_178259's avatar
Andrew_G_178259
8 years ago
Public Interface w/DHCP
I'd like to get setup an interface to use DHCP to get its assigned address; then use that address for a number of pre-defined virtual servers under LTM.
Is this something possible? Using an iRule for assigning the IP?
Thanks in advance.
Regards, Andrew
  • Hamish's avatar
    Hamish
    Virtual Servers don't use DHCP. Their addresses are statically configured.
    So out of the box. No... But... If you really wanted to, you might be able to work something up that allocates an address externally and then uses iControl to create your VS's.
    Or... And this would be fun, but not sure how practical, create a wildcard VS that manages EVERYTHING (And I mean everything) in an iRule. So the iRUle does the DHCP request, and then rather than creating VS's, simply manages the traffic dynamically itself..
    The Second one is probably completely impractical...
    H
