JasonHeffner_71's avatar
JasonHeffner_71
Jan 16, 2009
ProxyPass redirect problem
I'm having some strange issues with proxypass and redirects. I have proxypass setup as follows
/login some.server.edu/login connectstagingapp
/manage some.server.edu/manage connectstagingapp
and generally this works as expected. However when I attempt to do a response.redirect in asp which is behind proxypass to a url outside on the same server, the BigIP will continue to serve files through proxypass for all urls on the host, even those that aren't specifically listed in the Data Group List.
The stranger thing this is dependent on browser, where this is the case on Firefox and IE, Safari will correctly handle the redirect.
Does anyone have an idea what might be causing this?
