Mohammed_Banaja's avatar
Mohammed_Banaja
Nov 05, 2014
ProxyPass port from 9.x to 11.4.0, data group not processed properly
we recently moved our web services from a ver 9.x box to a ver 11.4.0 box. we have data groups defined (also from ver 9.X for a specific subdomain where traffic for that subdomain is forwarded to different back end host than the VS's assigned pool:
ltm data-group internal /Common/ProxyPassvs_www-suncor-com_https { -----> v 11.4.0 records {
        data suncor-prod/
    apps.suncor.com/aquarius {
        data "10.8.35.18/aquarius pool_web-c1p_http automap"
    apps.suncor.com/mrms {
        data "10.8.35.18/mrms pool_web-c1p_http automap"
    forthills.suncor.com/ {
        data forthills-prod/
    sustainability.suncor.com/ {
        data sustainability-prod/
type string
now for some reason after testing we discovered that the "automap" portion of the data group is not being processed. we figured that the ProxyPass iRule we're using for ver 11.4.0 maybe have been misconfigured when adapting it to 11.4.0. Below are the snippets from 9.x
Store each entry in the data group line into a local variable
set clientside [getfield $ppass " " 1]
set serverside [getfield $ppass " " 2]
set newpool [getfield $ppass " " 3]
set snataddr [getfield $ppass " " 4]
. . . . Take care of pool selection and SNAT settings
     if {$newpool eq ""} {
        pool $default_pool
        if { $::ProxyPassDebug > 1 } {
           log local0. "$log_prefix: Using default pool $default_pool"
        pool $newpool
        if { $::ProxyPassDebug > 0 } {
           log local0. "$log_prefix: Using parsed pool $newpool"
     if {$snataddr != ""} {
        snat $snataddr
           log local0. "$log_prefix: Using SNAT address $snataddr"
        HTTP::header insert "X-Forwarded-For" "[IP::remote_addr]"
and here is ver 11.4.0
set serverside [string trimleft [getfield $ppass " " 2 ] "{" ]
set newpool [string trimright [getfield $ppass " " 3 ] "}" ]
 If serverside is in the form =match=replace=, apply regex
if {$serverside starts_with "="} {
    set regex [getfield $serverside "=" 2]
    set rewrite [getfield $serverside "=" 3]
    if {[regexp -nocase $regex "$orig_host$orig_uri" 0 1 2 3 4 5 6 7 8 9]}{
         The clientside becomes the matched string and the serverside the substitution
        set clientside $0
        set serverside [eval set X $rewrite]
        pool $default_pool
        return
The following code will look up SNAT addresses from
 the data group "ProxyPassSNATs" and apply them.
 The format of the entries in this list is as follows:
 All entries are separated by spaces, and both items
 are required.
set class_exists_cmd "class exists ProxyPassSNATs"
if {! [eval $class_exists_cmd]} {
    return
set snat [findclass $newpool ProxyPassSNATs " "]
if {$snat eq ""} {
     No snat found, skip rest of this event
    return
if { $static::ProxyPassDebug > 0 } {
    log local0. "$log_prefix: SNAT address $snat assigned for pool $newpool"
snat $snat
you'll notice that "snataddr" is not defined in the ver 11.4.0 iRule. how can I port that portion of the config to the 11.4.0 iRule and will that address this issue?
any help would be appreciated.
thanks
