Proxy for encrypted TCP socket connection
Hello - we have made great use of the codeshare examples including extensive use of the HTTP Forward Proxy - v3.2 irule and I see that there are also proxy irule examples for ftp, smtp, ldap and mysql. Is there a way using an proxy irule or perhaps a forwarding virtual server to be able to use the f5 to forward an encrypted TCP socket connection from behind our f5 to an external site ? We currently have this working using a squid proxy server using PREROUTING, POSTROUTING, DNAT and SNAT iptables rules but would prefer using the f5. Can the f5 be configured to behave like the squid proxy server ?
- Arnaud_Lemaire
Employee
Hello Tom, do you mean you want to do TCP session forwarding to a fqdn host which should be resolved by BIG-IP ? 11.6 allows you to specify fqdn pool members with resolution done by BIG-IP. That could solve you issue without touching irule.
- Amit_Karnik
Is the SNAT IP on a different subnet for which the server does not have a route back ?
Can you add a tcp monitor on the pool and check if the member shows up ? If it does, try setting the snat to Automap.
