Protected WorkSpace Help
Does anyone know if its possible to create a link ( whether url or a network drive) where my users who go into protected workspace can update their antivirus DAT. I cant seem t figure out a way to do this on protected workspace.
Most of my vpn users go into protected workspace due to DAT not updating while they are on my network so I am hoping to make it easier for them when they VPN .
- Seth_Cooper
Employee
I don't think it will work since protected workspace keeps everything. I would suggest if they fail the AV check and need to update the definitions you can give them a network tunnel with only access to the AV mgmt server to get the definitions. You could also run a script to force the AV to update. After this they disconnect, reconnect and they are directed by policy to the resources the need.
Seth
