epaalx's avatar
epaalx
Icon for Cirrus rankCirrus
Jul 19, 2020
Proper way to exit vconsole whilst nested
Hi Experts,
our Avocent terminal servers establish console access as telnet sessions - in this case, to vCMP Host. BIG-IP vconsole is itself a telnet session to vCMP Guest. So, together, it's a nested terminal session and pressing '^]' shows outer session options (ie. Avocent) instead of inner (vconsole).
What is the graceful method to terminate vconsole and return to vCMP Host - killing telnet session (as question about vconsole utility) doesn't feel right?
R's, Alex
BIG-IP 12.1.5 Build 0.78.6
Kernel 2.6.32-431.56.1.el6.f5.x86_64 on an x86_64
5250v-vcmp-guest-1.local login:
Console escape. Commands are:
 l     go to line mode
 c     go to character mode
 z     suspend telnet
 b     send break
 t     toggle binary
 e     exit telnet
