Cristiano_Costa's avatar
Cristiano_Costa
9 years ago
Problems using ASM and Web Accelerator/AAM
Hello everyone,
I am having problems to get the ASM module to work with the Web Accelarator / AAM.
The article https://support.f5.com/csp/article/K14880 describes some conditions for both modules to work together. As described in the document, in my setup if bigip receives a valid request and does not generate a violation the cache works.
However, if an invalid request is received and generates a violation, all other valid requests for the same URL are no longer cached. This happens regardless the request origin.
For example, consider requests for . All valid requests for "/index.html" are cached. However, at the moment a request for "/index.html" generates a violation, any other valid request for "/index.html" are no longer cached.
That seems odd to me.
Is this an expected behavior? Or am I missing something?
Obs:
I'm using Bigip VE 12.1.2
To run the tests, I created an empty ASM policy and activated the signature attack: Automated client access curl. This policy prevents users from using command line "curl" to access the home page. So, I did:
  1. From machine 1, I access the URL from a valid browser. I verified that the request was cached.
  2. From machine 2, I access the URL using the "curl". I verified that the request was NOT cached and the ASM reported a violation.
  3. From machine 1, I access the URL from a valid browser. I verified that request was NOT cached and the ASM did not raise any violation for this request.
