Keith_Odom_1073
Jan 18, 2005Problems downloading the 4.x SDK
I downloaded the iControl 4.6.2 sdk for Windows. The file created by the download is : iControl-4[1][1].6.2.zip. When I try to unzip this file winZip indicates that there is an error with the file.
The error is : End-of-central-directory signature not found. Either this file is not a Zip file, or it constitutes one disk of a multi-part Zip file.
Am I doing something wrong? Anyone else having this problem?
Thanks,
Keith
- Loc_Pham_101863Historic F5 AccountKeith,
I just downloaded the same SDK, and was able to extract the ZIP file successfully. I suspect you had some network disruption or connectivity problem that might have corrupted the file. Please give it another try.
Loc - The problem could be with the size of the file and a network hiccup between our server and your machine. Try downloading the unix version (.tar.gz). This is about 1/5th of the size and is able to be opened with Winzip on windows.
-Joe
