Julian_Balog_34
Oct 21, 2009Historic F5 Account
Problem with non-default installation path
(originally posted by: Roquencourt, Jean-Baptiste
Thanks for the new version [1.4.1.93], the installation runs fine.
However, I try to change the installation path, and whereas the installation was successful I couldn't launch a discovery because the link points to the default installation path.
- Julian_Balog_34Historic F5 AccountHi Jean-Baptiste,
We found that there’s an issue with the F5 Management Pack server tasks (defined in SCOM), which still point to the default installation folder (%Program Files%/etc…). Our next release of the Management Pack will have this fix included.
Thank you for sharing with us the issues that you have with the F5 Management Pack. We'll do our best to unblock you as soon as possible and make the F5 MP a better product.
Julian
F5 Management Pack - SUSmtr_82330
It sounds like the issue mentioned above may be related to a problem I'm seeing too.
The server we installed the F5 MP on (the latest 1.4.1.93 version) does not have a C drive. The drives are remapped to non-standard letters. For example, the system drive is X: rather than C, so that %PROGRAMFILES% is 'X:\Program Files'
During the F5 MP install, it correctly recognized the different drive letter for the default installation as 'X', so I used that.
The MP was installed in that default X:\Program Files directory. HOWEVER, when I try to use it within the SCOM console, the action tasks tools on the right side of the console all reference a C drive, so none of them work.
For example, if I click on the F5 Action 'Discover F5 devices', it fails and pops up a message stating:
"Application C:\Program Files\F5 Networks\Management Pack\f5mpgui.exe
Parameters: -DiscoverDevices
Error Message: The system cannot find the file specified"
It is similar for the other F5 action tasks available.....
Will that be fixed too?
It appears I can run the commands manually from a command prompt referencing the correct path, but it would be nice to have this flexible enough to recognize the proper drive within the icons in the SCOM console.
Thank you
