Problem with Exchange iRule after 11.2 upgrade
Hello,
I need some help determining what this error message means that has shown up in my logs since upgrading to 11.2.
Error Message status code 01220001:
TCL error: /Common/EXT_MIN_EXCH_2010_SINGLE_PERSIST - attempt to use empty persistence key (line 1) invoked from within "persist uie [HTTP::header "OutlookSession"] 3600" ("MSRPC" arm line 3) invoked from within "switch -glob [HTTP::header "User-Agent"] { "MSRPC" { if { [HTTP::cookie exists "OutlookSession"] } { persist uie [HTTP::header "Outlook..." ("/rpc/rpcproxy.dll" arm line 2) invoked from within "switch -glob [HTTP::path] { "/Microsoft-Server-ActiveSync*" { persist cookie pool EXT_MIN_EXCH_2010_SINGLE_AS } "/rpc/rpcproxy.dll" { s..."
This message is in reference to the IRule we use for exchange that worked in 10.2.4 and 10.2.0:
when HTTP_REQUEST priority 600 {
persist cookie
"MSRPC" {
persist uie [HTTP::header "Authorization"] 3600
"*Microsoft Office*" {
default {
persist source_addr
pool EXT_MIN_EXCH_2010_SINGLE_OA
"/autodiscover/autodiscover.aspx" {
persist cookie
pool EXT_MIN_EXCH_2010_SINGLE_OWA
default {
persist cookie
I am assuming it is a syntax issue with the new version of firmware, but I am not the expert! Can someone please assist?
Thanks,
Megan Smith
- O2hitman_109315NimbostratusI am also having the same issue, the only difference is that it is only happening on a single member of a device group. The irule works fine on the other member and these errors don't occur. Strange.
- Sanjit_126167Nimbostratus
After upgrade of F5 into 10.2.1 to 11.2.1 with HFix9. I'm also getting similar kind of issue. Mon Nov 11 13:55:27 CST 2013 err tmm[7360] 01220001 TCL error: /Common/******* - attempt to use empty persistence key (line 1) invoked from within "persist uie [HTTP::header "OutlookSession"] 3600" ("MSRPC" arm line 3) invoked from within "switch -glob [HTTP::header "User-Agent"] { "MSRPC" { if { [HTTP::cookie exists "OutlookSession"] } { persist uie [HTTP::header "OutlookSession"] 3600 ..." ("/rpc/rpcproxy.dll" arm line 2) invoked from within "switch -glob [HTTP::path] { "/rpc/rpcproxy.dll" { switch -glob [HTTP::header "User-Agent"] { "MSRPC" { if { [HTTP::cookie exists "OutlookSession"] } {...
