ML_62682's avatar
ML_62682
17 years ago
Problem with ClickOnce programs
I have an application that stops running everytime I run Firepass. We use ClickOnce technology for deployment of the application; that way the app will be updated automatically every time there is a new update on our website; but instead of updating the application, it asks me to install even though the app is still installed (all app files can be found in the %profile%\Local Settings\Apps\2.0 and the Add/Removed Applications still displays that the app is installed).
Any help will be greatly appreciated!
  • Hi there.
    I know this is an ancient thread, but as it still stands unanswered and I came up with exactly the same issue a latter version of the F5 SSL VPN software, I thought that would be good to share my findings.
    The exact cause of not being able to install a ClickOnce application when on the SSL VPN, might be because of the way F5 has decided to configure the network proxy settings while on the VPN.
    If you are using WPAD (wpad.dat file) to get your proxy configuration to the end-users, at VPN establishement the F5 client will cache a (slightly modified) copy of the wpad.dat file locally. It stores the configuration in the dial-up connection settings and references the file using a file:// URI.
    Microsoft issued a security advisory (MS12-074: Vulnerabilities in .NET Framework could allow remote code execution) that disables file:// WPAD parsing for WinINET/.NET components that I believe the ClickOnce installer is using.
    Effectively, ClickOnce applications will not work when on a F5 SSL VPN if you are using WPAD-style proxy autoconfiguration.
    A possible workaround is to enable this setting in the registry:
    Key:   HKLM\SOFTWARE\Policies\Microsoft\Windows\CurrentVersion\Internet Settings\
    Value: EnableLegacyAutoProxyFeatures
    Type:  REG_DWORD
    Data:  1
    That will disable the security patch new behavior and let .NET components parse file:// auto-configuration URIs. Microsoft denotes that this should only be a temporary solution.
    A better solution would be for F5 to update the way they are publishing the modified wpad.dat file locally, using a local embedded HTTP server in the VPN client would be my idea.
