Puli
Dec 09, 2010Problem with # in URLs
Am parsing below types of URLs in an iRule
www.abc.com/docs/example1.html re-directs to www.abc.com/newdocs/example1.html
www.abc.com/docs/example1.htmlhic re-directs to www.abc.com/newdocs/example1.html
www.abc.com/docs/example1.html?l=en re-directs to www.abc.com/newdocs/example1.html
Am using
set base [HTTP::path] to the uri and search that in a datagroup and re-directs accordingly.
Am having a problem with the second url in Firefox and chrome
when accessed www.abc.com/docs/example1.htmlhic
FF and chrome appends hic to the response in the browser address bar. IE works fine.
Any ideas how i can remove hic to not appear in Browser address bar.
I turned on logging but i cannot see hic comming in the request.
looks like browser is send only the uri part and ignoring hic and appending it to response.
How can i prevent it from doing that via an iRule.
Any tips.
Appreciate your help
Puli.
- hoolio
Hi Puli,
The in URIs is an anchor tag. It's used to tell the browser where in an HTML document to focus the page. HTTP user agents shouldn't send the anchor tag in the HTTP request line. So HTTP::uri shouldn't show the anchor. If you want to logically remove the anchor from URIs for datagroup lookups, you could use getfield to split the path on and take the first field:
http://devcentral.f5.com/wiki/default.aspx/iRules/getfield
Aaron
