Problem upgrading from v11.2.4 to v11.6.0
I have lost a couple of partitions and lots traffic objects. When I ran "/usr/libexec/bigpipe daol", I got the following error:
"Loading the configuration ... BIGpipe unknown operation error: 01070630:3: The requested data group file (/config/filestore/.stage_d/1_d/Common_d/data_group_d/:Common:vlanMapping.dat_49354_1) was not found or empty)."
Now, if I run "ls -al /config/filestore/.stage_d", I get:
ls: /config/filestore/.stage_d: No such file or directory
What can I do to get out of this?
Any help is appreciated.
- nitass
Employee
is it possible to manually comment the data group (/config/bigpipe/bigip.conf) and load the configuration (/usr/libexec/bigpipe daol) again? then add the data group back later.
- Hamish
Cirrocumulus
Load the config from tmsh by hand. E.g.
load sys configOr from bash
tmsh load sys configAnd check for errors. I suspect you have something else in the config that it doesn't like
H
- JG
Cumulonimbus
I have resolved the issue with the following steps:
- I tried to load the ucs file from the old v11.2.4 using tmsh:
tmsh load /sys ucs /var/tmp/v10orig.ucs.tar.gz no-license
(Note: My ucs files does not contain the latest license. Lesson: Always save a ucs file after re-activating the license.)
This will give more detailed output as to where the problem is. Then I untar the ucs file in that directory:
mkdir /var/tmp/my_conf; cp /var/tmp/v10orig.ucs.tar.gz /var/tmp/my_conf; cd /var/tmp/my_conf/; gzip -dc v10orig.ucs.tar.gz |tar xvf -
Then I edited and commented out each of the problematic parts in config/bigip.conf or other files.
Then I re-tar the directory:
rm v10orig.ucs.tar.gz; tar -zcvf v10confmodified.ucs *
and load the new ucs file again. Repeat this process until it is clear (need to remove the ucs file that has an error in it before tar-up of the dir each time.) Take note of the warnings so that you fix the issues later on. Then I get:
"Post-processing... Reloading License and configuration - this may take a few minutes... Full configuration has been loaded successfully."
Bingo!
