lamine_diagne_1
Oct 16, 2009problem irule
I have a problem can you help me
here are the error
line 166: [use curly braces to avoid double substitution] [($generic_err_msg)]
line 460: [use curly braces to avoid double substitution] [[clock clicks -milliseconds]]
line 472: [command is not valid in the current scope] [if { [matchclass [URI::decode [string tolower
- hoolio
I'd guess you have a mismatched parenthesis or brace, but it would be easier to help if you post the full iRule.
Aaron - lamine_diagne_1
here is the irule - hoolio
I think the issue is between the LB_SELECTED and LB_FAILED events. Either that, or you copied the iRule section twice. It appears that the section starting with " COMMENT :: SQL INJECTION detection" is listed in the word doc twice.
Aaron
