ELORF's avatar
ELORF
Sep 19, 2019
problem integrating icap into asm of F5 14.1
I followed this tutorial https://support.f5.com/csp/article/K70941653
but i have a problem in integrating icap into asm of F5 14.1,
asm does not send files to icap Trend Micro antivirus.
I have configured the IP address, the port and the iCAP_URI (/ reqmod, / REQ-Service, / AVSCAN)
no result!!!
  • ASM needs to see the file upload in a multipart form with the file name specified as a parameter before it can send the request to ICAP.
    If you just POST the file, then ASM cannot (currently) detect the upload and send it to ICAP.
  • ELORF's avatar
    ELORF
    Thank you for your reply
    How to configure this setting to send files at ASM level?
  • This is application level behaviour within the web application itself - there isn't any configuration in ASM to enable this behaviour.
    https://developer.mozilla.org/en-US/docs/Web/HTTP/Methods/POST
    POST /test HTTP/1.1
    Host: foo.example
    Content-Type: multipart/form-data;boundary="boundary"
    --boundary
    Content-Disposition: form-data; name="field1"
    value1
    --boundary
    Content-Disposition: form-data; name="field2"; filename="example.txt"
    value2
    --boundary--
