xinhui_jiang_20
Jul 12, 2015problem about monitor outside isp network
hello
my scenario is below:
internal address is 192.168.0.1/30
external address is 10.0.0.1/30
manage address isp use static route 3.3.3.3 to 10.0.0.1 like this,when monitor check outsite websit...
VernonWells
Employee
Jul 19, 2015Is 3.3.3.3 an IP address that is assigned to the BIG-IP? If so, you could bind it to the BIG-IP as a self-IP, then create a route to the external hosts going through the default route upstream of 3.3.3.3.
If this is not feasible, then, as this post describes:
you could have the monitor target a VS on the BIG-IP that performs SNAT. The VS would have a single pool members; namely, the IP:port of the target you wish to monitor.
As yet another alternative, you could create an external monitor. The following post provides information about this:
