coolhill_17403's avatar
coolhill_17403
18 years ago
Priority Group Issue
The version is 9.1.2 HF8.
I have four servers,There are two servers in a priority group.
My setup is as follows:
Webmethods server 1 setup with priority group 2 and Priority group activation "Less than 1".
Webmethods server 2 setup with priority group 1.
After setup completion,Why will the member of low priority be also assigned session.
Thanks!!
  • Hi Coolhill,
    That is not suppose to happen.
    The current version you are running has 2 specfic bugs related to your case that was supposed to be fixed in version 9.1.3.
    Here is the following URL to the ASK F5 Support (You have to be registered to view it)
    http://tinyurl.com/2fmxzm
    My overall suggestion is that you upgrade to version 9.1.3 of the 9.1 branch.
    One more thing, are you assuming that the connection is going to the incorrect priority based on the information presented by the BIGIP or did you obtain that by seeing the connection on the actual server?
    Thanks,
    CB
  • There is the session of incorrect on that server.
    I will try to upgrade 9.1.3.
    Thanks for you help.
  • zafer's avatar
    zafer
    Hello
    i have http_pool and it contains 6 members
    i want set backup for like this
    server2 backup for server1
    server4 backup for server3
    server6 backup for server5
    if server1 goes down i want make up server 2
    if server3 goes down i want make up server 4
    if server5 goes down i want make up server 6
    is that possible
    zafer
