Power supply down alert
Receiving power supply1 alert, status shows down. Unfortunately, site support is available in eastern hrs. Is there anything else can be checked remotely, before confirming power supply is down and logging trouble ticket with F5 support.
Sep 11 00:22:01 dallas-2 emerg system_check[9891]: 010d0006:0: Chassis power supply 1 has experienced an issue. Status is as follows: FAN=bad; VINPUT=bad; VOUTPUT=bad
tmsh show sys hardware|grep -iA 5 "Chassis Power Supply Status" Chassis Power Supply Status Index Status 1 down 2 up
Device details:
Platform Name BIG-IP 8900F BIOS Revision OBJ-0331-01 - Build: 90036 Base MAC 0:23:e9:4e:87:0
Version 11.2.0 Build 2805.6 Edition Engineering Hotfix HF7
Also, can only power supply be changed without disturbing the unit?
- StephanManthey
Nacreous
You will need to open a support case on this issue.
According to the platform guide, the PSUs of 8900s are hot swappable.
