Ports requirement for Failover Pair
Hi Everyone,
I just need to ask a quick question regarding the ports used by the device in fail-over pair, Which ports (TCP & UDP) should be allowed on the SELF and Floating IP on the Device to make sure the Iquery runs properly and the boxes get synced properly without failure. Also if you can provide some commands to quickly track down the proper working of syn or if there is some problem/error.
Regards,
- nitass
Employee
sol9057: Service port and protocol used for BIG-IP network failover
http://support.f5.com/kb/en-us/solutions/public/9000/000/sol9057.html
you should see it in connection table.
e.g.
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) show sys connection protocol udp Sys::Connections 200.200.200.13:58921 200.200.200.11:1026 200.200.200.13:58921 200.200.200.11:1026 udp 0 (tmm: 1) none 200.200.200.12:35008 200.200.200.11:1026 200.200.200.12:35008 200.200.200.11:1026 udp 0 (tmm: 0) none 200.200.200.11:46165 200.200.200.12:1026 200.200.200.11:46165 200.200.200.12:1026 udp 0 (tmm: 1) none 200.200.200.11:53355 200.200.200.13:1026 200.200.200.11:53355 200.200.200.13:1026 udp 0 (tmm: 1) none Total records returned: 4and this is for configsync.
sol13946: Troubleshooting ConfigSync and device service clustering issues (11.x)
http://support.f5.com/kb/en-us/solutions/public/13000/900/sol13946.html
