pool/members port issue
In the REST api, when I GET a pool members (ex: https://lb/mgmt/tm/ltm/pool/pool_name/members/) service port is missing. I have service port in "name" field but a "resolved" port like "octopus" for 10008, for example ! But in my case, it's a web server : 10008 is not used by octopus but by apache.
Could you add a "servicePort" field please (with the numerical value) ?
- Michael_Yates
Hi Broutard,
Look at the raw config on the device and see if the config is saving the Service Name instead of the Service Port as well.
If so, look at SOL14345: The BIG-IP system now saves the service port as a number in the configuration and then run the TMSH Command to change from service names to ports.
tmsh modify cli global-settings service
I haven't played much with the new REST API, so if this is your issue and this corrects it please let me know.
Hope this helps.
