POOL SHOWS 'Inactive' when Node is configured with RADIUS protocol
I wanted to configure RADIUS/UDP protocol in LoadBalancer
- I've Created Virtual Server with protocol type UDP
- Created a node and add in a pool. (with 1812 port)
- Make sure that 1812(radius server) is up and running
Now Pool shows Inactive , and showing Children in pool are down.
Is there any relevant document to configure RADIUS protocol over LoadBalancer
- svs
Hi srkraju,
it seems that the node itself is offline or forced offline/disabled. In this case the Pool Member is marked with "parent node unavailable". You should check the status of the node and the configured monitor, used to check the nodes status. Per default a nodes status is checked using the default monitor, which is "none" in a factory default configuration.
If this doesn't solve you issue it would be great to see some screenshots of the node, pool member and pool.
Greets, svs
