Abed_AL-R
Mar 09, 2021plink command in powershell | problem with imish
Hi
I'm trying to send "imish" command via powershell to f5 and it is not working
I tried:
- imish
- run /util imish -r 0
both ways did not work
I also tried to send the command in the same line like this:
plink [email protected] -pw 12345 imishand via external file like this:
plink [email protected] -pw 12345 -m E:\myfolder\imishcommand.txt- Any other command like "show" or "list" is working fine
- If I do it gradually, step by step, first by passing the credentials and then when I'm in I write the "imish" command, it is working fine
The user I'm using has the administrator level. I also tried with the local "admin" user and the "root" user.
Why I'm not able to send the imish command along with the plink command
Alternatively, if there is a way to check "show ip ospf neighbor" without entering the "imish"
- Abed_AL-R
