Sumit_Singh_383's avatar
Sumit_Singh_383
Apr 02, 2019
Solved
Please help me in below iRule which is not working for me.
Hi Team, my above irule is not working. Please help me on urgent basis. I want to use this irule to identify the client browser then re-direct their request to specific pool member.
  • Hi ,
    Try this:
    if { [HTTP::header User-Agent] contains "ipad" }  {
            pool Pool-2
    } elseif { [HTTP::header User-Agent] contains "Android" } {
            pool Pool-3
            pool Pool1
    Many thanks,
    Karim
  • Hi ,
    Try this:
            pool Pool-2
            pool Pool-3
            pool Pool1
    Many thanks,
    Karim
    • Sumit_Singh_383's avatar
      Sumit_Singh_383
      Hi Karim, Thank you so much. It is working for me now.
      May i know what mistake I was doing.
      Regards, Sumit Singh
    • Karim_Benyello1's avatar
      Karim_Benyello1
      Icon for Cirrus rankCirrus
      Sure, you typed "IF" while it should be "if". iRules are case sensitive.
      Many thanks,
      Karim
  • Hi ,
    Try this:
            pool Pool-2
            pool Pool-3
            pool Pool1
    Many thanks,
    Karim
      Sumit_Singh_383
    • KarimBenyelloul's avatar
      KarimBenyelloul
      Many thanks,
      Karim
