as_102351's avatar
as_102351
Sep 29, 2010
PING problem
hi, i have big ip 9.4.2 and have HA with a network failover, the failover works fine and sync ok, but if a make a ping from self Failover Address to peer Failover Address works but if i cancel and make a new ping, the new ping dont answer. Any have the same problem?
  • while run the ping in one session, I duplicate the session to make a "tcpdump -i failover proto \\icmp", i can see the ip's works but in the ping utility shows nothing.
