Will_'s avatar
Will_
Mar 16, 2012
Persistence Records and Cookie Insert
I do not see persistence records when configuring Cookie Method "HTTP Cookie Insert" (regardless of setting session or timer), and do see them with "Cookie Hash" and "Source Address " persistence.
I searched the usual locations and cannot locate an explanation. Does the group here have an explanation?
  • hoolio's avatar
    hoolio
    The advantage to using cookie insert persistence is that the cookie is the persistence record. LTM doesn't need to maintain a record in its memory as the client is responsible for providing the cookie which has an encoding of the pool member IP:port.
    sol6917: Overview of BIG-IP persistence cookie encoding
    https://support.f5.com/kb/en-us/solutions/public/6000/900/sol6917.html
    Aaron
