Persistence not honored with iRule on session hash
This is my first post, so I apologize if I miss something.
We're using a BIG-IP 11.4.1 Build 637.0 Hotfix HF3 to route HTTPS traffic from a central data center IP to our application pool. Load balancing is occurring via an iRule based (see below). For the most part, persistence is maintained, but occasionally a different pool member gets routed to. This causes an undesired result in our application. We've had a case open with support but haven't gotten resolution to this thus far. We've tried the following:
Route based on sourceIP - overloaded single pool member because traffic was coming single IP.
Tried using LB::detach based on KB article from support: https://support.f5.com/kb/en-us/solutions/public/7000/900/sol7964.html This actually caused the undesired effect in the application to occur more frequently.
Here is our iRule:
when HTTP_RESPONSE { set SessionHash [HTTP::header "X-IntegrationServer-Session-Hash"] if { $SessionHash != "" }{ persist add uie $SessionHash 21600 } } when HTTP_REQUEST { set cli [IP::remote_addr]:[TCP::remote_port] set SessionHash [HTTP::header "X-IntegrationServer-Session-Hash"] if { $SessionHash != "" } { persist uie $SessionHash 21600 } }
Any and all help is appreciated. Thanks, Michael C.
- Mohamed_Lrhazi
Altocumulus
Try to capture a fiddler session and full tcpdump, both client side and server side, of a session where persistence broke. then analyse the cookie exchanges to find out where it broke.
- StephanManthey
Nacreous
Hi Michael,
are you using OneConnect (to be assigned to the virtual server via profile).
In case of clientside connection pooling (i.e. applied by proxies) multiple clients may share a single keep-alive connection.
Without OneConnect the virtual server does not de-multiplex the incoming requests and persistence is just applied based on the very first request after the connection was opened.
Thanks, Stephan
