f5_learner_2857
Jan 29, 2010Persistence Cookie Logger - undefined procedure
Hello,
I am using the following iRule given at http://devcentral.f5.com/Wiki/default.aspx/iRules/Persistence_Cookie_Logger.html
and am getting the following error. Please advise what could be the problem.
Thanks.
Error:
01070151:3: Rule [PersistenceCookieLogger] error:
line 1: [undefined procedure: rule] [rule persistence_cookie_logger {
iRule:
when RULE_INIT {
see AskF5 SOL6917 for cookie encoding details:
https://support.f5.com/kb/en-us/solutions/public/6000/900/sol6917.html
set ::myCookieName BIGipServerXXXX
set ::debug 0
grab encoded cookie value & parse into relevant pieces
if {[HTTP::cookie exists $::myCookieName]}{
scan [HTTP::cookie $::myCookieName] "%d.%d.%d" myIpE myPortE unused
if {$::debug != 0}{log local0. "myIpD=$myIpE myPortE=$myPortE unused=$unused"}
calculate IP
%08x format strings forces padding w/leading 0's to 8 char string
set myIpH [format %08x $myIpE]
if {$::debug != 0}{log local0. "myIpH=$myIpH"}
set myIpD1 [expr 0x[substr $myIpH 6 2]]
set myIpD2 [expr 0x[substr $myIpH 4 2]]
set myIpD3 [expr 0x[substr $myIpH 2 2]]
set myIpD4 [expr 0x[substr $myIpH 0 2]]
set myIpD "$myIpD1.$myIpD2.$myIpD3.$myIpD4"
if {$::debug != 0}{log local0. "myIpD=$myIpD"}
calculate port
set myPortH [format %x $myPortE]
if {$::debug != 0}{log local0. "myPortH=$myPortH"}
set myPortD [string trimleft [expr 0x[substr $myPortH 2 2]][expr 0x[substr $myPortH 0 2]] 0]
if {$::debug != 0}{log local0. "myPortD=$myPortD"}
log results
log local0. "Request from client: \
[IP::remote_addr]:[TCP::remote_port] contains persistence cookie \
referencing pool member $myIpD:$myPortD"
log local0. "Request from client: [IP::remote_addr]:[TCP::remote_port] \
contains NO persistence cookie"
- hoolio
If you're adding the rule via the GUI or the iRuler, you need to leave off the object definition line:
and the matching close curly brace at the end.
Aaron - Kirit_Patel_521
I am using the persistence_cookie_logger irule . How come I don't see the cookie value. The only thing i see is :
Dec 18 07:49:00 tmm tmm[2317]: Rule persistence_cookie_logger : Request from client: 63.116.166.102:57254 contains persistence cookie referencing pool member 172.28.24.106:80 - Chris_Miller
Altostratus
Posted By Kirit Patel on 12/18/2010 04:51 AM
Because that's what you're logging. The logging statement logs the source ip:port and the pool member being used. - Kirit_Patel_521
Ok is there anyway to display the cookie value? - Chris_Miller
Altostratus
referencing pool member $myIpD:$myPortD and value $myCookieName" - hoolio
Did you change BIGipServerXXXX to the name of your actual persistence cookie?
Aaron
