Jace_45978's avatar
Jace_45978
Mar 19, 2012
persistence based on uri call
would like to add persistence profile if client makes call with /admin in the uri to the VS otherwise there is no persistence on the VIP.
I plan on adding a universal persistence to the VS with this following iRule can someone let me know if i am on track?
client makes call to https:///dispatch/admin/StartAdmin.html
virtual fp230 {
snat automap
pool ds-8080
destination 10.10.10.10:https
ip protocol tcp
profiles {
fp230-stg_sslprofile {
clientside
http {}
tcp {}
profile persist f3p_35min_persist {
defaults from source_addr
mode source addr
timeout 2100
thinking the irule would look like this??
if { [URI::path] contains "/admin" } {
persist f3p_35min_persist }
  • Hi Jace,
    this looks good so far, the irule should look like this:
            if { [HTTP::uri] starts_with "/admin" } {
                   persist source_addr 255.255.255.255 2100
    If the clients accessing this application are not behind any form of nat, it can be a good solution.
    However, it is always better to persist higher up the stack, just in case.
    Is there any cookie you could hook up on ? If not, are you allowed to set a cookie ?
    Thanks,
    Christian
  • we are unable to persist based off cookie. This is one of those VS that the only persistence they want is when they go to the admin console.
    I noticed that my previous post http string didn't post correctly.
    The call the client makes is https://VS_server.com/dispatch/admin/StartAdmin.html all other non admin console calls would be https://VS_server.com/dispatch/somethingelse.html
    That is why i was thinking of putting the "contains" in the irule.
    No natting. thanks for the input.
  • Hi Jace,
    makes sense. Based on your input, the irule should look like
            if { [HTTP::uri] equals "/dispatch/admin/StartAdmin.html" } {
    Means only when starting the admin console at that specific path, a persistence record is created.
    Christian
  • Great thanks Christian. I we will be implementing this rule tomorrow I will let you know if there are any issues. I appreciate your input!
  • hoolio's avatar
    hoolio
    I think the persist command might stay in effect for the rest of the connection. So you might want to disable persistence for non-matching URIs:
          persist none
    Aaron
  • I actually have a follow-up
    I have following irule:
    if { ([HTTP::uri] contains  "Communication") or ([HTTP::uri] contains  "Builder") }{
               persist cookie
               pool XYZ
     elseif { ([HTTP::uri] contains  "PDFTemp") or ([HTTP::uri] contains  "DOCTemp") or ([HTTP::uri] contains  "Servicenew") or ([HTTP::uri] contains  "ServiceCorrespondence")}{
                 log local0. "Client IP = [IP::client_addr]"
                 persist none
                 pool ABC
    But I am not still seeing Persistence on second pool ABC and I had to put the Persistence method cookie on Virtual servers Resources, Default Persistence Profile Section.
    If I don't put that on the Virtual server, it gives an error that irule is using Persistence method so VS needs to have "cookie" in VS > Resources > Default Persistence Profile Section : "Cookie"
