Frederic_Zeller's avatar
Frederic_Zeller
May 07, 2008
Peristence on X-Forwarded-For
Hi.
Using Universal Persitence, it's quite easy to persist on a part of the URI. Many example can be found.
Like :
persist uie [findstr [HTTP::uri] "user=" 5 "&"]
But I'd like to persit on one of the Header field (X-Forwarded-For)
Cookies can't be used due to multiple URL being used. ( part of the site is http, other part with different URL is https ).
Source address can't be used due to all client being behind a single proxy
Has anyone done any persitence on a header field ?
From the manual, I know it could be done, but how ?
Any Help would be greatly appreciated ..
TIA
Fred
  • hoolio's avatar
    hoolio
    Hi Fred,
    You can replace '[findstr [HTTP::uri] "user-" 5 "&"]' with '[HTTP::header value X-Forwarded-Fo]'r. However, there might be multiple XFF header values in client requests. The HTTP::header command will return the last value. Proxies aren't required to insert an XFF header, so you wouldn't be guaranteed to get a valid value to persist off of. If the proxy in your scenario does insert an XFF header, the HTTP::header command should work for persisting off of the value.
    Aaron
  • Hi Aaron
    Just tested that :
    persist uie [HTTP::header "X-Forwarded-For"]
    log local0. [HTTP::header "X-Forwarded-For"]
    and it works great
    Guess it will by the proxy responsability to insert the correct header ...
    THANKS A LOT!
