chris_connell_1's avatar
chris_connell_1
Apr 21, 2009
Performance issue
Hello
we have a viprion with 2 blades and using fast l4 virtual servers with 100 real servers using, although we have 10gb connections to these the customer is complaining that there is a 1.5gb bottleneck and response times are slowing after this.
Are there any useful session/connection limit stats i can check? i have seen the b conn fasl4 show but dont know if its really utilized or not. Top reports the system is not loaded either.
Thx for any help
  • Hi,
    By default there should not be any connection or session limits in place. What do the throughput graphs in the Performance section show? How is the customer determining this throughput value? If it's some sort of load generating tool I would be skeptical, it's usually the tool itself that becomes the bottleneck.
    Denny
