Ty_Barwick_9494
Apr 26, 2011PeopleSoft http monitor help
I followed the Deployment Guide for F5 with PeopleSoft Enterprise Applications . It has a basic http monitor setup; however, it doesn't do anything. I need to configure the Send String and possibly the Receive String variables, but need help.
Here is my login for PeopleSoft http://f5testps.uw.edu/psp/pstst3/?...uageCd=ENG
I can actually login through F5, only if I disable the http monitor.
I tried GET /xmllink/E_REC/TCHH_WEB_DOWN_PAGE HTTP/1.1\r\nHost: f5testps.uw.edu/psp/pstst3/?cmd=login&languageCd=ENG&\r\nConnection: close\r\n
Any help would be appreciated.
Thanks,
Ty
- hoolio
Hi Ty,
The host header should only contain the domain for the request. Can you try this?
GET /psp/pstst3/?cmd=login&languageCd=ENG HTTP/1.1\r\nHost: f5testps.uw.edu\r\nConnection: close\r\n\r\n
If you're on a version lower than 10.2.0, remove the last \r\n from the send string.
If that works with no receive string then try setting the receive string to either "HTTP/1\.(0|1) 200" or "HTTP/1\.(0|1) 302" without the quotes.
Aaron - Ty_Barwick_9494
It worked!! Thanks for your help Aaron, it is much appreciated.
