Partition Issues v11.3
Hello I have two LTMs (69000 versión 11.3 HF3). I've tried to install 11.4.1 on a volume. There has been no problemn with the first LTM but the second one fails. It looks as if there's a problem that prevents the installation of the image that I have uploaded. I've tried to delete the volumes but there another error: show sys software status
Sys::Software Status
Volume Product Version Build Active Status
MD1.1 BIG-IP 11.3.0 3138.5 yes complete MD1.2 BIG-IP 11.4.0 2384.0 no failed to delete volumeset MD1.3 BIG-IP 11.4.1 608.0 no failed to delete volumeset
Then I've tried to install on a new volume with another error: show sys software status
MD1.1 BIG-IP 11.3.0 3138.5 yes complete MD1.2 BIG-IP 11.4.0 2384.0 no failed to delete volumeset MD1.3 BIG-IP 11.4.1 608.0 no failed to delete volumeset MD1.4 BIG-IP 11.4.1 608.0 no failed (Can't find requested disk MD1.)
Now , if I try to install the software again there one more error: install image BIGIP-11.4.1.608.0.iso volume MD1.3 01020036:3: The requested mcp_software_desired (MD1.3) was not found.
Any help thank you
Might be worth opening a ticket with support on this one. I'm not certain but there could be a problem with your RAID.
- nitass
Employee
i guess the problem may be gone after rebooting.
just my 2 cents.
- soymanue
Hello I opened a support case and it has turned out to be a bug ID427409 that won't be resolver until version 12.0 You have to stop MySQL, empty AVR database and restart services
- ab30_149107
Dear Manuel, I am facing the same issue. Can you please give the commands for -- You have to stop MySQL, empty AVR database and restart services. Thank You, Abhisar.
