OWA with Enterprise Vault and SSO
We have a Exchange 2013 setup, where only for accessing OWA the APM-module is in use with SSO. This works fine.
Now we want to integrate the Enterprise Vault plugin as well. The EV-links are resolved to the same VS (different subdomains) and we made already the required adjustments (Domain Cookie, switch SSO profile in the iRule). This works also fine, but if we try to open an email within EV, which will be opened in a dedicated window/tab, it just shows the header information. The body/content of the email will not be displayed.
With IE11 within the body section the APM logon page will be displayed again with the error message: "JavaScript is not enabled. Please enable JaveScript in your browser..."
With FF the body section is just white and nothing will be displayed.
Any idea what's the issue here and how this can be fixed are at least further troubleshooted? We are using 10.2.4 if this might be important.
Thank you!
Ciao Stefan :)
- Stefan_Klotz
Cumulonimbus
Hm, I'm not sure if this is really an issue with the APM and SSO. Because I disabled APM for the EV-links and then the NTLM popup will be displayed (as expected). After entering the correct credentials with:
- IE: everything seems to be fine, body of the mail will be displayed. Also downloading the email via icon on the top right works fine.
- FF: body-part of the email still stays blank/white. Besides that the download icon on the top right also don't function correctly. I'm getting the following error (after a few seconds): GetOnlineAttachmentFileSize 0x80072AF9
Is this maybe related to any specific setting in one of the profiles? Or do I have to adjust something special?
Thank you!
Ciao Stefan :)
- Stefan_Klotz
Cumulonimbus
In the meanwhile I could at least identify the root cause for the APM error message when using IE.
The content of the mail will be loaded with such a request:
/EnterpriseVault/Properties.asp?content=1&VaultID=1BE4A431283....but for whatever reason the APM session-cookies are NOT included. All previous requests incl. images and css are fine including the required APM session-cookies.
Any idea what's the reason for this or how this can be solved?
Thank you!
Ciao Stefan 🙂
- Stefan_Klotz
Cumulonimbus
Found out another strange thing. I tried it with a third browser (Chrome) and here everything is fine.
So this means it's more a local browser issue, but I currently have no idea where and what to search for.
Any ideas or hints would be very useful.
Ciao Stefan :)
- Stefan_Klotz
Cumulonimbus
Almost there, but still not working :(
During further investigation with Fiddler I found out the reason, why the above mentioned URL is not including the cookies in IE. It's an embedded iframe. Around this topic there is a very interesting discussion here.
But adding the mentioned P3P header within the HTTP_RESPONSE event still don't solves the issue. Additionally I see that this iframe has the security="restricted"-flag set. Not sure if this has any additional drawbacks. I tried to remove it with a stream-profile, but didn't get that working at all.
Maybe someone else is more familiar with this topic and can help me here!
At the end it's again "thanks to Microsoft and IE"!!!
Ciao Stefan :)
- Stefan_Klotz
Cumulonimbus
Hi Ruben,
yes I implemented a workaround for IE in the meanwhile, which seems to work fine. The only small drawback of this solution is, it assumes that each parallel connected client has a unique IP-address (so no NATing in between).
I added the following lines at the beginning of the HTTP_REQUEST event:
if an email from the archive will be opened, the APM session-ID will be stored in the session table based on the source-IP (assuming it's unique for all clients) if { [HTTP::uri] starts_with "/EnterpriseVault/ViewMessage.asp" } { table set -subtable [IP::client_addr] lastmrh_session [HTTP::cookie LastMRH_Session] 900 table set -subtable [IP::client_addr] mrhsession [HTTP::cookie MRHSession] 900 } the content if the email is embedded via an iframe, where IE is blocking all cookies therefor the cookie will be added based on the information from the session table if { [HTTP::uri] starts_with "/EnterpriseVault/Properties.asp" } { HTTP::cookie insert name "LastMRH_Session" value [table lookup -subtable [IP::client_addr] lastmrh_session] HTTP::cookie insert name "MRHSession" value [table lookup -subtable [IP::client_addr] mrhsession] }But still have no workaround for FF, where the issue seems that FF is not sending the iFrame request at all. Chrome was working fine from the beginning and iOS devices haven't been tested yet.
Hope that helps or at least point you in the right direction.
Ciao Stefan 🙂
