am_gli_287451's avatar
am_gli_287451
Jul 25, 2018
Outlook clients not working with iapp for exchange 2016
I've just implemented the iapp for MS Exchange 2016. Everything works properly (OWA, EAS, etc.) - except the outlook clients themselves.
When starting Outlook with host-entries adapted to the F5 VS, Outlook isn't able to connect. We use a pretty simple setup with LTM for loadbalancing, SSL-Bridging, no AFM, no APM. All services share the same IP.
For Outlook clients, MAPI- and RPC-over-HTTP are chosen.
In the troubleshooting section of the deployment guide, there is a part regarding "clients experiencing Outlook connectivity issues", which would be a possible problem in our case, but even by adjusting the Idle-Timeout like suggested in the irule (CAS 15 minutes -> irule 1200 seconds), the problem still persists.
    switch -glob -- [string tolower [HTTP::path]] {
     "/ews*" -
     "/oab*" -
     "/mapi*" -
     "/rpc/rpcproxy.dll*" {
     TCP::idletime 1200
     return
Any other ideas or hints, what or where to check?
Thanks!
  • Self-resolved -> adding an additional irule to the configuration as proposed in the DG doesn't work. You have to adapt the generated irule "XXX_combined_pool_irule7":
             Outlook Anywhere.
            TCP::idletime 1200
            pool /Server_LAN/XXX_exc_int.app/XXX_exc_int_oa_pool7
            COMPRESS::disable
            CACHE::disable
            return
