OSPF adjencecy between an F5 LTM and the NSX edge
Hello,
i'm trying to build an OSPF adjencecy between an F5 LTM and the NSX edge the pings are ok but the neighbors state stack in Exstart state. to know there is not a missmuch between mtu equipements.
do any one have the same situation? is there any ideas ?
Thanks a lot
- fire12_313356
Altocumulus
for person who is interest, it's work very good. If you have any question i can help
- Ilian_Ivanov
I am interested :) Can you share more details?
- fire12_313356
Altocumulus
what do you know exactly ?
using an F5 VM in nsx u have first to load ARM module and then you configure your F5(self ip VLans ....) you create a virtual switch in nsx create an interface in nsx activate ospf in the edge create a area map your interface in this area and indicate the same area when configuring F5 LTM module and do no forgot to autorise this in the nsx firewall .
have other questions ? specifics ones maybe .?
