Thiyagu's avatar
Thiyagu
Icon for Cirrus rankCirrus
Jun 18, 2020
Order of precedece of failover
Hi Team,
Could you please help me know to about the order of precedence failover:
1 - If the HA cable connectivity goes down, then the does load balancer failover from Active to Standby?
Or
If the HA of load balancer fails, then it will check the rechability to load balancer-2 via mgmt network to ensure the other device is up?
Regards,
Thiyagu
  • Hello Thiyagu,
    You can set the Failover Preference order in the traffic-group (Device Management ›› Traffic Groups).
    Regards
