Oracle HTTPS Load Balancing issue
Hi ,
We are trying to load balance Oracle https application . When we are trying to access the application through virtual server ip it is continuously giving certificate error and after continuous clicking " not this time " it is showing application error .
But if we shut down one Node the application is working fine through Virtual IP .
I am not sure whether it is happening due to persistance .
Can anybody has idea on this issue .
- Emad
Can you share VS configurations.
How many nodes does it have; If it is shutting a particular node that resolves the trouble, you might want to dig into that node.
- Indrajit_Basak_
It has two nodes . Its not a particular node . If I shut down either of the node the application is working fine . But when both the nodes are up then while accessing application i am getting continuous certificate error and after multiple click i got error page .
you might want to test with SSL persistence, Would yield more suggestions, if you could share config
