sims2009_290343
Jan 08, 2017open connection
Hi, F5 stattics dashboard shows x number of open connection and snmp traps shows y number of open connection at same time .
y is 1 /3rd of x
? Please help
- Vijay_E
Cirrus
You may have to open up a ticket to get an official confirmation and the answer can vary depending on code & platform version that you are utilizing. I had a similar issue in the past and was asked to trust SNMP more than the F5 dashboard.
