Hemant007_33294's avatar
Hemant007_33294
Sep 08, 2017
Not able to see cookie contents using curl command
I am not able to see the cookie contents using curl -k -ss -D- -o /dev/null -L -H 'Host:host URL' IP/. My device is BIG-IP LTM and its version is 12.1.2
  • Adding the "
    -v
    " parameter to cURL displays the header data (including the Set-Cookie headers inserted by the BIG-IP or by the real server)
