neeeewbie's avatar
Sep 25, 2019
No traffic flowing when running tcpdump
Hello!!!
I need your help!
When setting interface mirror, I want to check the traffic to the mirror port. When using tcpdump -nei 1.1, no traffic flows to the mirror port. If you turn off tcpdump, traffic flows.
If you know the cause please let me know.
dest mirror port: 1.1 // mirrored port: 1.2, 1.3
Thank you.
    • neeeewbie's avatar
      neeeewbie
      Icon for MVP rankMVP
      Thanks!
      How do I check a packet without using the tcpdump command?
      • Anjuli_L's avatar
        Anjuli_L
        You should use an external capture device attached to the network interface to analyze (sniff) traffic that is mirrored to the interface. Hope that helps!
  • Are you trying to capture on the Standby? If this is L7 mirroring then try tcpdump on the same interface you'd receive external traffic if the box were Active.
      neeeewbie
      yes, F5 team release new note relate to this situaltion
