neeeewbie's avatar
9 months ago
No entry for wideip in AST
These are the additional settings in the YAML file:
f5.gtm:
enabled: true
objects:
wideip:
enabled: true
names:
-a
-aaaa
pool:
enabled: true
monitor:
enabled: true
Even if the entry is added, the wideip entry is not reflected.
  • Hello neeeewbie,
    Glad to see you have AST installed!
    To understand the issue, first, which YAML file did you make this change in? If it was config/ast_defaults.yaml or configbigip_receivers.yaml, you'll need to run the Configuration Helper after making the change, if you haven't already done so. (If you are editing services/otel_collector/receivers.yaml directly, you can skip this step.)
    Second, did you restart the tool after making the change?
    Lastly, take a look at the available data types supported in AST for options that can be enabled. It looks like you may have a few that are not in this list.
    • neeeewbie's avatar
      neeeewbie
      Icon for MVP rankMVP
      I modified the bigip_receivers.yaml file and ran docker compose down/up, but the changes weren't reflected properly.
  • I don't see most of those metrics listed in the available data types . Can you test this out by just including f5.dns and f5.gtm as enabled metrics (and leaving out the others you have listed above)?
    Also, once you've completed those changes, you'll want to re-run the Configuration Helper .
  • I tried to collect by registering both f5.gtm and f5.dns, but DNS-related information (wiedip pool, etc.) is still not collected.
    • JasonEpstein's avatar
      JasonEpstein
      Have you restarted Docker Compose? If so, are you now seeing the "GTM Overview" and "Requests Rate By Type" panels appear on the BigIP - Device >> Device GTM dashboard, but with no data, or are you still seeing the same set of panels on this dashboard ("Enable For All BigIPs" and "Enable For Select BigIPs") and nothing else?
